Author Topic: Newbie question_Timer in Sequence Diagram  (Read 5643 times)
googlealll
« on: October 26, 2006, 04:30:46 am »
Hi all,
When I draw Sequence Diagram, I see there is no timer symbol like that:
__
/_\
to set timer and stop it.
Does EA have timer symbols and where I can find it?
Thanks in advance.
Googlealll
Jan ´Bary´ Glas
  • Bary
Re: Newbie question_Timer in Sequence Diagram
« Reply #1 on: October 26, 2006, 04:45:02 am »
Try Recieve element from Activity Toolbox. From its context menu pick Advanced/Accept Time Event.
« Last Edit: October 26, 2006, 04:47:00 am by Bary »
Jan 'Bary' Glas
googlealll
« Reply #2 on: October 26, 2006, 06:52:40 am »
Thanks for your reply, Jan.
However, when I drag the Receive symbol into the current Sequence Diagram, it becomes the Event1 rectangle box instead of the usual shape in Activity diagram. I change it to Accept Time Event. But it changes nothing.
If I do this in Activity diagram, it works. So, do you know what I need to do to have a timer symbol like the one in your picture in Sequence diagram?
Thanks so much
Jan ´Bary´ Glas
  • Bary
« Reply #3 on: October 26, 2006, 07:36:54 am »
The interaction in sequence diagram does not allow using this.
The messages are not sent by time object, but a real entity. When it is sent is a different thing. Thing of using Seguence Expressions in Message properties.
Jan 'Bary' Glas
« Reply #4 on: October 26, 2006, 03:17:20 pm »
I think what you need to use for a sequence diagram is a message end point (Black circle) as this annotates an external message.  If you want to make it clear that this is a timer event you can add an attached note.
