Author Topic: navigability and OCL  (Read 7330 times)
SF_lt
  • The Truth Is Out There
« on: October 24, 2006, 02:31:25 pm »
UML 2.1 superstructure states, that UML tools can traverse through a non-navigable association ends.
So suppose there is a metamodel's fragment:
class A and class B are associated with a association with the association ends endA and endB respectively. endB end is non-navigable.
Does it mean, that it's possible to write OCL expression using navigation through the non-navigable endB end?
context A
inv: endB.name <> 'test'
However model's (which conforms to metamodel) objects ClassA (instance of metamodel's class A) won't be able to use endB association end?
« Last Edit: October 24, 2006, 02:50:14 pm by SF_lt »
registertm everything to SparX
Re: navigability and OCL
« Reply #1 on: November 02, 2006, 05:46:16 am »
If you give us a reference in the UML specification, we'll have another go at answering your question...
SF_lt
« Reply #2 on: November 02, 2006, 07:44:52 am »
UML Superstructure v2.1, p. 39, right after the 8963 issue
