Author Topic: Version 3.51 - Build 603 Released  (Read 22241 times)
sparks
« on: February 25, 2003, 09:49:31 pm »
Changes in Build 603
Fixed error in C# parser that could occur where unmatched strings in summary comments occurred
Fixed error in removal of classifier from Boundary still showing name of previous classifier
Modifed drawing code in sequence diagrams to underline full name of instances
Modified drawing code to force resize of connection labels to best fit of text
Modified C++ parser to correct problem with importing file with complex template definitions
Modified Delphi parser to correct problem with handling of quoted strings in certain comments
Fixed problem with EA on SQL Server when running test report and selecting "Passed, Failed, or Not Run"  option
Included attribute tag notes in RTF documentation
Added new interface to EA.Repository object "OpenFile2(Variant Filename, Variant Username, Variant Password)" - use to open a password protected model from automation
Fixed issue with handling of .EMF files which have been saved with .WMF extension
« Last Edit: February 25, 2003, 09:59:49 pm by sparks »
