Author Topic: XSD generation problems II  (Read 10674 times)
atingley
« on: February 03, 2005, 12:57:19 pm »
Ok, I thought I had this down, but am seeing some weird behavior with multiple packages and XSD...
I have 3 pkgs, A, B, C; A is the "base" package, and defines "base" types.  B and C are "extension" packages, and define new types in terms of extensions to those defined in A.
All three packages are configured to have the same namespace.
When I generate the schema for pkg A, it generates two <xs:include> elements, one for pkg B, the other for pkg C!
The generation of B and C are ok - they generate an <xs:include> element referring to pkg A, as expected.
There are no references *from* pkg A  *to* pkg B or C.  Why would there be an <xs:include> element generated in the output schema file?
benc
Re: XSD generation problems II
« Reply #1 on: February 09, 2005, 04:52:18 pm »
Hi atingley,
Thanks for the note. As far as I can tell this a bug - schema A definitely shouldn't require includes, if the pacakge doesn't contain references to C and B.
We'll try to get this resolved ASAP. Thanks again for letting us know.
Ben
VK
« Reply #2 on: April 17, 2005, 04:05:17 pm »
Hi atingley,
The issue regarding <xs:include> has been resolved for the next release of EA  :)
Cheers.
Tomas
« Reply #3 on: May 20, 2005, 06:30:45 am »
Hi vkumar,
I've just downloaded EA 5 and the problem still exists  >:(.
It keeps adding include elements to packages that are not supposed to be there...
Was the fix removed from the release?
VK
« Reply #4 on: May 22, 2005, 04:21:06 pm »
Hi Tomas,
This bug has definately been fixed. Would it be possible for you to send in a model reproducing your problem to Sparx Support ?
Tomas
« Reply #5 on: May 23, 2005, 12:47:51 am »
Hi vkumar,
I've sent the issue as a bug where I've added a model where it is possible to reproduce the error.
