Author Topic: Vertical fork/join  (Read 5340 times)
Donafani
Vertical fork/join
« on: May 27, 2005, 08:38:27 am »
I have to create a vertical fork/join in a new diagram by using Vb6 automation interface...
I just can create it horizontally, this is my code example:
Dim Pack As EA.Package
Dim FJoin As DiagramObject
Dim JoinElem As Element
dim d as EA.Diagram
Set JoinElem = Pack.Elements.AddNew("", "Synchronization")
 JoinElem.Update
Set FJoin = d.DiagramObjects.AddNew("l=20;r=50;t=100;b=130", "")
  FJoin.ElementID = JoinElem.ElementID
  FJoin.Update
Can anyone help me to make this fork/join synchronization in vertical way???
Re: Vertical fork/join
« Reply #1 on: May 29, 2005, 04:19:55 pm »
You will need to add:
JoinElem.Subtype = 1
Where Class is "Synchronization", use Subtype = 0 for horizontal, Subtype = 1 for vertical. This should have been documented: I have updated the help file for the next release; apologies for the omission.
Neil
« Last Edit: May 29, 2005, 05:51:20 pm by KP »
