Author Topic: Display association as attribute  (Read 7319 times)
IritP
« on: May 15, 2007, 03:45:02 am »
I have 2 classes (A, B) and I add direct association between them (A->B).
In a diagram I add A.
I want to see that A has an attribute of type B (without adding B to the diagram).
According to UML2.0 this feature is mentioned...
Re: Display association as attribute
« Reply #1 on: May 15, 2007, 04:37:05 am »
Until the AssociationEnd is named, there is no Attribute under UML 2.x.
Unfortunately, EA (806) still does not automatically support a Named AssociationEnd as an Attribute.
You have to do it manually.
IritP
« Reply #2 on: May 16, 2007, 02:01:39 am »
Thanks Paolo.
Could you tel me how can I edit AssociationEnd property manualy?
I can't found this property. I tried to add name to targer role but it doesn't help.
Irit
« Reply #3 on: May 16, 2007, 02:15:26 am »
Thanks Paolo.
Could you tel me how can I edit AssociationEnd property manually?
I can't found this property. I tried to add name to target role but it doesn't help.
Irit
Hi Irit,
It is better to add the attribute first and then it will appear in the source/target (as appropriate) dropdown when you open the Association Properties.
