Author Topic: Accessing Current Element from Add-In  (Read 9835 times)
fwoolz
« on: February 11, 2005, 12:45:07 pm »
Hi All,
Is there an automatic way to access and manipulate the current element via the Automation Interface in an Add-In?
Fred Woolsey
Interfleet Technology Inc.
Re: Accessing Current Element from Add-In
« Reply #1 on: February 13, 2005, 02:03:33 pm »
You have a choice: Repository.GetTreeSelectedItem or Diagram.SelectedObjects, depending on whether you want the objects selected in the Project View or on the diagram.
Tip: your EA_MenuClick event will give you a MenuLocation parameter which will tell you where the add-in was called from, i.e. diagram, main menu or project view.
The EA help file has more info. e-mail me if you get stuck  :)
Neil
tugelblend
  • /* You are not expected to understand this */
« Reply #2 on: May 31, 2005, 05:51:20 am »
Neil
could you please give an example for that. I've got the problem, that the GetCurrentDiagram-Method doesn't work for me (f.e. when selecting a Use Case in the Diagram View).
For being a VB Newbie maybe I'm doing a basic thing wrong. This is my code:
Sub Set_Object_As_Source(ByVal Repository As EA.Repository, ByVal Location As String)
   Dim currentDiagram As EA.Diagram
   Case "Diagram"
               currentDiagram = Repository.GetCurrentDiagram()
The last line causes error '91 - Object variable or With block variable not set'.
What am I doing wrong?
I would appreciate any help. Thanx.
Hauke Altmann
« Reply #3 on: May 31, 2005, 06:35:19 am »
Hauke,
In VB, you need to use the "Set" syntax for object variables.
Thus:
   Case "Diagram"
     Set currentDiagram = Repository.GetCurrentDiagram()
Should do it...
« Last Edit: May 31, 2005, 06:36:21 am by PaoloFCantoni »
tugelblend
« Reply #4 on: May 31, 2005, 07:21:06 am »
Paolo,
thanks. Works now to that point. I will take a deeper look in my vb book to avoid another question like that  ;).
Hauke
