Author Topic: Generate C# Code from Sequence daigram  (Read 7091 times)
pegah
« on: May 26, 2007, 11:59:36 pm »
hello.
I want to know how can i generate C# code from Sequence diagram model.I know  that could generate sequence from code, but don't know if can reverse it?
thanks very much.
Re: Generate C# Code from Sequence daigram
« Reply #1 on: May 27, 2007, 01:05:03 pm »
Not directly you can't.  EA only generates from the class model.  However, if your sequence diagram(s) has/have been set up using instances of actual classes and the messages correspond to actual methods.  Then you'll be able to generate the class model you have created.
pegah
« Reply #2 on: June 19, 2007, 01:16:15 am »
Thanks you  very much.
but i do'nt know how generate C# code from Sequence Diagram.
can you tell me a way to do it?
thanks very much again.
