Author Topic: Extending an existing project  (Read 7316 times)
Jesmond
  • Where there is a will there is a way!
« on: August 26, 2007, 12:02:45 am »
Dear all,
I have a contract assignment to analyse and subsequently modify/recommend an existing web based application (small add-in application).
I have reverse engineered the models into EA professional (as mush as possible), and a next step I plan to add/modify the model in order to reflect the changes required for the new requirements.
I am note familiar what proper UML discipline I should use in order to modify functional requirements, modify business processes, use case models, etc.
Should I just create new views/diagrams, or just modify the structure (I would loose the history, since I do not have version control enables). I could copy/clone the project, and use a "two copy".
Note: This project scope is limited to the business analysis / inception stage only (possible more if the customer decides to use EA for the whole project lifecycle).
I would appreciate any point of views from experience users how would this be tackled.
Best regards,
Jesmond
jeshaw2
Re: Extending an existing project
« Reply #1 on: August 26, 2007, 10:32:48 am »
[SNIP]
[SNIP]
[SNIP]
It depends upon several things
  • Did the reverse engineering produce a model at the same level of abstraction as the one you need to produce?
  • Do the new features <<include>> or <<extend>> existing Use Cases or do they introduce new Use Cases?
  • Does your definition of Business Analysis include or exclude the work of a Solutions Architect?
  • How well can your stakeholders read UML Diagrams?
jeshaw2
« Reply #2 on: August 31, 2007, 07:09:19 pm »
Is this thread dead?  :-/
Jesmond
« Reply #3 on: August 31, 2007, 08:04:33 pm »
Hi Jes,
Sorry for not following up, and thanks for your interest.
Following up on the project I imported the existing requirements, and used EA custom model to express the underlying relationships. Additionally I split then into three separate packages. Then I created a separate package to contain the new and/or changed/extended requirements. I am not quite sure how to you express a change" or "extension" using EA requirements custom diagrams though.
As far as the use cases, unfortunately the were not re-usable, since the previous project had actually (perhaps inadvertently) performed functional decomposition, and actually express functions rather than a use case! So I am re-defining the use cases.
At the moment I am concluding the documentation for the inception phase of the project, for which I have been following the OpenUP guide (http://www.eclipse.org/epf/) that I found quite useful.
Jesmond
