Author Topic: Generalization of requirements  (Read 7280 times)
GBeutler
« on: November 07, 2007, 09:56:12 am »
in EA it is possible to model generalization of requirements.
i.e. a requirement hast to fulfill all of another requirement AND something else. Is it a good idea to model this as generalization? A composite dependency would work also but i am not clear about what would be the correct way of modeling this. Is generalization of requirements part of the uml standard?
thanks in advance and best regards,
Guido
Re: Generalization of requirements
« Reply #1 on: November 07, 2007, 10:55:53 am »
bruce did write a bit about "structured" requirements. I would summarize as follows. Requirements need to be flat. Each one must be independent of the other. However, during capturing phase you will find requirements that are alike. What I do is to use aggregation. That does give a clearer picture and you can continue to remove redundant requirements. I definitely would avoid using generalization.
« Reply #2 on: November 07, 2007, 12:07:50 pm »
Like Thomas says...
There is an example of aggregation of requirements in the EAExample project.
