Author Topic: Deployment Model  (Read 7095 times)
Martin Spamer
Deployment Model
« on: February 01, 2008, 03:52:50 am »
I currently trying to model a live domain with a deployment model.
To support our platform governance programme I want to record some things that are not normally found on deployment models.  e.g. logical server name (CName), physical server name (AName) and IP address.
I'm looking for ideas on how to express these effective on deplyment model.  Hopefully in a way I can use to generate hosts files.
« Last Edit: February 01, 2008, 04:41:28 am by Martin_Spamer »
Re: Deployment Model
« Reply #1 on: February 01, 2008, 05:28:13 am »
Hi Martin,
There is an option to show both the name and alias of an element, if both were present and differed. They are shown as (alias) name, on two lines. You must have the Use Alias setting for the diagram checked. [This sometimes will not show up until you reload the diagram.]
You can show the run state of a node on a deployment diagram. Run states can be entered for elements, not just objects. They can also be entered for arbitrary variables, not just defined attributes. [You might want to use attributes though; they will appear in the drop-down, which will help insulate you from typos.]
You can also define tagged values, and use Set Feature Visibility to see the tagged value compartment. Check out Custom tagged values for how to set up an IP mask (for example) so the values will look correct. [You have to turn on the tagged values compartment, either manually or through automation, for each element or each diagram. At the diagram level use the Elements tab of the Diagram Properties Dialog. At the element level, to save time you can select several (or with control-A, all) elements on a diagram and set them as a group.]
HTH, David
