Author Topic: Version 3.51 - Build 605 Released  (Read 22406 times)
sparks
« on: March 11, 2003, 10:07:39 pm »
Changes in Build 605
Modified Operations and Attribute dialog to mark dirty when information pasted into notes field
Added Connector detail Heading and Row RTF to the RTF Style templates
Added a number of additional words to the 'Adjust Language' function in the RTF Documentation dialog
Fixed issue with saving comments in VB.NET where a ' was embedded in the text
XML Export option setting in View/Options dialog to make not exporting diagram details in XMI the default
Fixed issue with XMI export/import that could result in missing package in rare circumstances
Modified XMI 1.0 importer to better handle import of Model and Subsystem packages
Source and Target Role names added to RTF report on Connector Detail
Added Association start and end tagged values to XMI export using EA/XMI 1.1 style.
Fixed problem in Glossary dialog when using MySQL
Fixed problem in MySQL when invoking "convert linked element to local copy"
Fixed issue where imported property names in VB.Net always used "m_"<name>, and not option configured in View/Options Attributes/Operations
Fixed issue with Actor element causing problem when Attribute dialog invoked
Updated name wrapping routine to handle class names with embedded spaces
Updated Create New Project dialog to avoid resetting model filename after setting new filename
Stereotype dialog now re-sorts list on reload when a custom sort is in place
Modified code import to better handle use of Realization link to interfaces
Modified security subsystem to prevent one user viewing/altering another user's 'user locks'
Added "Exclude from RTF" option on Diagram Options Dialog to selectivey not show a diagram in and RTF export
Fixed problem that could result in sequence messages being re-wrapped to more than one line in Print Preview mode
