Author Topic: Two classes in one file?  (Read 6253 times)
janroos
« on: June 29, 2005, 11:44:33 pm »
Hi!
It is possible to specify filename manually when generating source code.
Is it possible to specify the source code filename for the generated class while doing model transformation?
Thanks!
Re: Two classes in one file?
« Reply #1 on: June 30, 2005, 03:27:31 pm »
You can specify filenames manually by opening the properties window, (View | Properties) selecting each class and setting the filename field.
At the moment it isn't possible to set the filename in a transformation, but once you've set the filename in a transformed class it should stay there.
Simon
