Author Topic: Use case diagram basic and alternate flows for EAI  (Read 6274 times)
dirkme
« on: May 09, 2008, 04:40:42 pm »
Hi, I am attempting an EAI use case diagram.
My question is how to model basic and alternative flows if I have a message sent from system A, to EAI, to system B or C. System A publishes a message, and based on its content EAI routes to either B or C.
2 questions:
1. Would this be modelled as two seperate basic paths?
2. Would exceptions be modelled as alternate flows?
Thanks  ;D
jfzouain
Re: Use case diagram basic and alternate flows for
« Reply #1 on: May 10, 2008, 02:34:39 am »
If I understand you correctly, this would be modeled as a basic path with a business rule in each flow.
Basic Path
1. System A sends a message
2. If message has rule x  is routed to System B
3. If message has rule y  is routed to System C
You can add an Activity Diagarm to this Use Case with a fork to route the message.
Hope it helps, but remember there are different ways to create this.
This is just one way.
Best regards
Jose Zouain
dirkme
« Reply #2 on: May 12, 2008, 08:00:18 pm »
Alternatively one can have multiple use cases "inheriting" from the base use case using the <<extends>> relationship. Would this make more sense? Then one would have seperate sequence diagrams for each use case. Any ideas?
