Author Topic: autosar software components using UML  (Read 7086 times)
silverline
« on: June 17, 2008, 06:28:15 pm »
Hi
i am new to the UML modelling technique. Can i get an example of any autosar compilant model for any software component.
Also in a class model when i use a 'class' and generate a .xml file, i would like to have only those attributes in the xml file to whom i have assigned some values. The rest of the values to which no values are assigned should not reflect in xml that i generate. Is there any setting by which i can achive this.
Thank you in advance
silverline
