Author Topic: Can we code generate the Sequence & Activity Diag  (Read 22573 times)
lols
« on: September 27, 2008, 01:37:57 am »
If the code is built, can the Activity and Sequence Diagrams be generated via code rather than by the developer.
Dermot
Re:  Can we code generate the Sequence & Activity
« Reply #1 on: October 01, 2008, 04:19:46 pm »
If the code built can be Run from EA - using the "Build, Test & Run" feature then yes you can generate sequence dagrams of a run through the code.
