Author Topic: Generating UML diagrams in EA  (Read 12294 times)
deva
« on: November 12, 2008, 10:55:27 am »
Presently i'm working in a research topic which gives output as classes and its associated methods using Rational unified approach.
Till now I developed those models automatically in Java which is quite tough for the user to modify them.  So I want to generate UML models in EA so that developer can modify as per his wish.
My input is a set of requirements. And my output is set of classes along with its attributes and methods. So I want this output to be in graphical class diagram form.
I'll be glad if I can have some basic idea at least how to proceed further.
Thanks in Advance.
Deva
OwenInCanada
  • have the right tool for the job
Re: Generating UML diagrams in EA
« Reply #1 on: November 13, 2008, 01:09:56 pm »
If you have examples of the classes, i.e. if you have code, then you can import the classes into EA using Code Engineering:
In the project browser, right click a package (looks like a folder).
From the context menu select Code Engineering / Import Source Directory...
and this can import Java.  I have not done this using Java, but I have done it using C.
Hope this is useful.
Owen
Dermot
« Reply #2 on: December 08, 2008, 04:30:15 pm »
