Author Topic: Java and arrays construct  (Read 12244 times)
cable000
« on: December 19, 2008, 07:41:22 am »
EA Version: 7.1.834
After importing the following code ( a.java and b.java ) in the model
a.java:
class A
   private B[] bees;
b.java:
class B
  private A a;
Now from the model if I generate code it changes a.java to
class A
  private B bees[];
So it moves the array operator after the member name.  Any ideas why it is doing this and how to correct?
Thanks!
Debesh
Re: Java and arrays construct
« Reply #1 on: February 03, 2009, 02:18:47 am »
When you reverse engg from source, the attribute
 private B [] bees;
is treated as a collection of type array... on fwd engg seperate attribute gets generated and thus the code becomes
  private B bees[];
Here is one example to show each attribute of type collection gets generated separately:
Import the below code for A.java, and B.java
class A {
private B [] bees, geese;
class B {
private A a;
Now fwd engg and you see smthng like...
class A {
      private B bees[];
      private B geese[];
class B {
      private A a;
