Author Topic: Deployment Model  (Read 14385 times)
amodir
Deployment Model
« on: August 06, 2009, 05:06:27 am »
  I'm new in UML and EA. But trying to build deployment model to show which components deployed on which server. I have several challanges. The first one is
I checked the EASample.EAP and saw that it uses Node instance and component instance and use dependency link with "Deploy" name on it?
why do we need to use dependency link and name it deploy instead of using deploy link?
Why using instance instead of artifacts?
Why can't we create instance of a package?
Why EAExample is using component instance instead of artifacts?
Which one should be used component instance or artifacts for deployment models?
« Last Edit: August 06, 2009, 05:11:03 am by amodir »
