Author Topic: UML Profile SOAML  (Read 21575 times)
zapolo
UML Profile SOAML
« on: August 01, 2009, 06:35:06 am »
hi
can not associate to my toolbox of SOAML diagram
I can help?
« Last Edit: August 01, 2009, 06:35:23 am by manuelalba »
zapolo
Re: UML Profile SOAML
« Reply #1 on: August 13, 2009, 05:54:25 pm »
I can help?
sxie
« Reply #2 on: August 14, 2009, 09:41:23 am »
Hi, there,
I assume that when you said "can not associate to my toolbox..", you meant the toolbox not being able to open when you open the SOAML diagram.
If this is the case, then better go to the «metaclass», check the string initial setting for attribute "toolbox". The initial should have exactly the same name as your Profile Package has.
Hope this help.
Regards, sxie
zapolo
« Reply #3 on: August 14, 2009, 07:00:03 pm »
thanks for reply
the problem is the attribute of the toolbox <<metaclass>> which was not put to use the toolbox of SOAML Component
« Reply #4 on: August 14, 2009, 09:19:25 pm »
Just to be sure... Did it work once you applied the «metaclass» stereotype?
zapolo
« Reply #5 on: August 19, 2009, 04:08:04 pm »
I don't understand what you ask
« Reply #6 on: August 19, 2009, 04:17:05 pm »
Hello zapolo. It is hard to know exactly what is wrong from the information you have given us. If you send your technology file (.xml) to Sparx support, someone will be able to inspect it and will be able to find out the problem. mailto: [email protected]
zapolo
« Reply #7 on: August 19, 2009, 04:50:42 pm »
I have already sent
thank you very much
