Author Topic: No notational indication for generalization scope?  (Read 30664 times)
g.makulik
« on: December 11, 2009, 11:06:47 am »
Is it really fact, that UML 2.2 doesn't specify a notational indication for generalization associations' scope?
Did anyone here come over the same problem? I've noticed that EA supports the specification of the scope in the generalization properties dialogue.
Currently I'm indicating this with a note in my diagrams :-(. It makes sometimes an important point in some of the C++ class designs I have created.
Günther
Re: No notational indication for generalization sc
« Reply #1 on: December 11, 2009, 11:59:32 am »
From memory it's worse than that.  UML has no no concept of it at all.  EA adds it for C++.
« Reply #2 on: December 11, 2009, 07:43:47 pm »
Günther,
Could you please explain what exactly you mean by
because I'm a bit like UML on this, I have no idea what you are talking about :-/
son-of-sargasso
« Reply #3 on: December 11, 2009, 09:29:03 pm »
Thank you Geert, I was too embarrassed to ask.  :-/
b
Makulik
« Reply #4 on: December 12, 2009, 03:58:22 am »
Hi Bruce & Geert,
Sorry, I'm afraid to be often too close to my programming language slang. With 'scope' I meant the visibility of the generalization's target end (i.e. the base class). There's a notational indication (+,#,- as usual) in  the UML specification of other associations ends, but none for generalizations. I think most (OO) programming languages support to specify it, at least C++ does. In the mentioned designs, I had good reasons not to specify this on the base classes operations level, but to hide the whole base class from (direct) public access.
WBR
Günther
« Reply #5 on: December 12, 2009, 04:00:14 pm »
So if I understood making a generalization private would be the equivalent of a regular generalization, and then overwriting all operation, making them private and calling the parent operation?
No I don't remember anything like that in the UML specs either.
Besides, are you sure this is a good idea?
What happens when I have a variable of type "Superclass" and it happens to be filled with an object of type "Subclass"? Am I now not allowed to call any of the operations on my variable anymore since they've been made private by the "Subclass"?
g.makulik
« Reply #6 on: December 12, 2009, 09:31:54 pm »
That is how it looks from outside, yes. But there are subtle differences.
In my special cases I want to achieve exactly this. It's about how to design interfaces, that are solely internally visible. In fact a (public) client will not be able to have a variable of type superclass filled in. An internal client may receive a 'variable' (or better an interface ref) from the subclasses though.
We had a recent discussion about the deprecated <<friend>> dependency stereotype here. That's the way how I factored out such <<friend>> dependencies from internal clients.
When you design frameworks this is a pretty useful pattern, to make your APIs 'idiot proof' ;). You can prevent your clients from using interfaces, they shouldn't use (directly), already at compile time.
WBR
Günther
[edit]PS.:
1. Actually I'm using an <<invariant>> constraint with the value 'protected' on the generalization, instead of a note.
2. I've investigated further, and see that it seems to be a more C++ related concept. At least C# and Java don't support it that way, these have a concept for module internally visible classes though AFAIK.
[/edit]
« Last Edit: December 12, 2009, 11:48:19 pm by g.makulik »
« Reply #7 on: December 14, 2009, 10:01:17 am »
« Reply #8 on: December 14, 2009, 11:59:58 am »
Look at http://www.parashift.com/c++-faq-lite/private-inheritance.html for a how/why to do this in C++.
Well, it DIDN'T get off to a good start...
private inheritance is a syntactic variant of composition (AKA aggregation and/or has-a).
NO IT'S NOT...
I'm not saying Public/Private Inheritance isn't a viable thing...  It just NOT Composition!
People often ask me why I use such long/uncommon words like meronymy - the relationship between the part and the whole.  It's because they are the right words...
"The reasons we can't build systems that work is that we can't unambiguously describe what we want to each other"  [size=8]Jean Raymond Abrial (1970).[/size]  Still true today...
If we think Inheritance is Composition, no wonder our systems don't work...
« Reply #9 on: December 14, 2009, 04:02:15 pm »
It may not be strictly composition, but it is a useful analogy.  In terms of modelling, the relationships between classes it would probably be more accurate to model it as composition than inheritance.
Do you have a better word for it?  (One that that average C++ developer would understand.)
« Reply #10 on: December 14, 2009, 04:47:51 pm »
Simon,
That's exactly my point...  It's NOT inheritance, it's composition.  The problem comes about because most programming languages' syntax is insufficient to express the concepts you're trying to model.  You yourself, I think, recently pointed out that when reverse engineering new code, the model can't determine if an association is a simple association or a meronymy without additional information.  That's because the language syntax doesn't distinguish between them.
In this case, under some circumstances, using the wrong syntax will appear to create the right result.  But if you've created the wrong model in the first place, it really doesn't help.
Since they're two separate concepts, there isn't a better word.  As I said before, I'm NOT arguing against scoping inheritance, I'm saying the example doesn't illustrate it - because a car ISN'T an engine (not notwithstanding dragsters... ;))
son-of-sargasso
« Reply #11 on: December 14, 2009, 07:06:15 pm »
I've gotta agree with the pope again here.  A car isn't a type-of engine, no matter which way you put it.  AND, yes we are talking about the example, not the concept.
However, getting back to the OP.  I'm still not convinced that what I perceive as the goal cannot be achieved using a facade pattern.  I really cant see the necessity(?) to confound the compiler when an exposed interface can be determined by a (or some) facade classes that will protect internals at very little expense.  I do understand what Cline is saying but it really stinks of making the model comply with the language constraints, or in this case the language features.
AFAIC the jury is still out.
bruce
« Last Edit: December 14, 2009, 07:08:09 pm by barrydrive »
« Reply #12 on: December 14, 2009, 07:24:54 pm »
Can't we achieve the same goal with the package visibilityKind?
If the superClass and its methods have package visibility, and the subclass is public, that would mean that classes from outside the package would be able to see the subclass and its public features, but not the superClass and its methods.
In the example of a framework design that would be exactly what you intended with the scoping of the generalization.
It looks like that is the UML way of modelling a situation like that.
son-of-sargasso
« Reply #13 on: December 14, 2009, 09:05:21 pm »
Geert,
Yes and no.  Package, aka "protected" is in the main still language dependent.  If, you really want to expose a specific set of aspects and really want to not expose a specific set of the internal workings of the component, then IME facades are the "best" way to go.
I mean, the damn things are usually so easy to specify.  All internals are "package private" and those things that we wish to expose can be just, well, exposed.  A bit like a 16yo in a shopping mall I guess, ya know that the scanty packaging is just a tease but any trying to open the package is "ILLEGAL".
(I'm probably going to get shot for that  :-X )
bruce
« Reply #14 on: December 14, 2009, 09:56:58 pm »
Whoa bruce, you've missed the ball there completely I think.
Package and Protected are two concepts defined in UML that have a really different meaning.
From the  UML superstructure 2.2
  • A protected element is visible to elements that have a generalization relationship to the namespace that owns it.
  • A package element is owned by a namespace that is not a package, and is visible to elements that are in the same
package as its owning namespace. Only named elements that are not owned by packages can be marked as having
package visibility. Any element marked as having package visibility is visible to all elements within the nearest
enclosing package (given that other owning elements have proper visibility). Outside the nearest enclosing package, an
element marked as having package visibility is not visible.[/list]
Having read this I must admit that missed the ball a bit as well, because you can't make the superClass package visible if it is owned by a package. (I really don't understand why they've added this restriction. Anyone know?)
You could make the operations package visible though, which would have the same effect.
