Author Topic: Modeling an UML Profile with OCL Constraints  (Read 15788 times)
SebastianW
« on: January 04, 2010, 08:31:31 pm »
Hi everybody,
I want to create an UML Profile that contains OCL Constraints.
After that I want to Validate my UML Model to see if the constraints are accomplished (If the Model was created in conformance with the given OCL constraints).
For the UML Model I use my created UML Profile.
In my UML Profile I have an association that should specify the following constraints:
"At the end and the start of the association are only specified stereotyped classes allowed"
My problem is that I don´t know how to write down this OCL that will be accepted by EA!
e.g.
UML Profile looks like..
<<stereotype>> isAssociated (contains OCL constraints see below)
extends
<<metaclass>> Association
<<stereotype>> MyClass_A and <<stereotype>> MyClass_B
extends
<<metalass>> Class
The constraints should looks like this:
context isAssociated inv:
self.base.participant.isStereotyped('MyClass_A') and
self.base.participant.association.participant
 ->exist(c|c.isStereotyped('MyClass_B'))
I tested that in EA it is possible to use "isStereotyped" but "participant" or "association" are not accepted.
Knows somebody where I can get an example or the supported OCL Syntax accepted by EA.
Thanks for your help
Sebastian
David OD
Re: Modeling an UML Profile with OCL Constraints
« Reply #1 on: January 29, 2010, 01:58:23 pm »
Sebastian
Did anybody enlighten you?  I would be keen to see this information myself.
Regards
beginner
« Reply #2 on: January 29, 2010, 08:03:11 pm »
I might remember this wrongly or EA could have been improved in that respect, but when I fiddled around with OCL I had the impression that EA is just checking the syntax of OCL, no evaluating it - which is a bit of a difference, you see?
b.
David OD
« Reply #3 on: January 30, 2010, 05:41:16 am »
A shame that.  Especially since I gather that there are some open-source OCL engines available.  I have raised an enhancement request.
Regards
SebastianW
« Reply #4 on: February 02, 2010, 11:32:31 pm »
I am disappointed...
The only way to solve this was that I have to develop my own EA Add-In. But that's not according to UML specification this is more an proprietary solution!
@David OD
sorry but nobody couldn´t enlighten me. And I also couldn´t find some examples that works...
@beginner
I quite agree you. EA is really checking the syntax of OCL.. no more, no less!!
