Author Topic: Version 3.51 - Build 608 Released  (Read 22455 times)
sparks
« on: April 13, 2003, 11:59:48 pm »
Changes in Build 608
Added 'Autosize Element' context menu option to single selected element
Fixed problme in Java generation of extends clause
Added notes section of linked requirement to RTF output - similar to notes for internal requirements
Prevented notes being modified and content lost when element is locked
Fixed cursor problem when connector type and then element type selected in toolbox - correct cursor shape now shown
Modified parameter type combo to mark record as dirty when type modified using arrow keys only
Checked size of run-state information when drawing elements and ensure element is wide enough to contain text
Fixed problem when adding additional Project Root nodes - sort order was reset to alphabetic instead of user configurable
Fixed problem where the 'constraint' field on a sequence message was not being written out to XMI
Fixed problem with print outs where Scale Image to One Page was selected. Often the font was being overly reduced.
Fixed display erro with Operation behaviour in class diagrams - behaviour notes now displayed correctly wrapped and next operation moved down a suitable amount
Fixed problem with NewElement Dialog (from Package contrext menu) being set invisible in some situations
Changed Diagram Hyperlink element so that it may have no text and the bounding box does not show - only the link icon
Changed wording of connector type in Connector dialog - now drop list contain Auto Routing as the second option instead of Routed
Schema generator modified:
     * EA now generates a complexType wrapper for attributes which are generated as elements and have a non-simple type.
         * The default model group is now "sequence", instead of "all"
« Last Edit: April 22, 2003, 11:14:52 pm by sparks »
