Author Topic: Access to Class parameters and arguments  (Read 9332 times)
« on: August 02, 2005, 12:38:56 pm »
In the automation interface, how can I get access to the Class parameters or arguments?  I can detect if they exist by using the Subtype, but I can't see how to get at them...
I'm talking about the properties available as ClassParameter and classArgument in the CTF.
Thanx,
« Last Edit: August 02, 2005, 12:42:36 pm by PaoloFCantoni »
Re: Access to Class parameters and arguments
« Reply #1 on: August 02, 2005, 04:00:42 pm »
It's available (to read) in the MiscData(2) field.
Simon
« Reply #2 on: August 02, 2005, 04:35:31 pm »
Simon
Thanx, Simon.
I'll check it out when I get to work.  Does this mean I have to parse it like I would the PDATA3 field?
« Reply #3 on: August 02, 2005, 08:07:17 pm »
Yes you will.
The things to look for are
<PRMn>=%classParamName%;
<TYPn>=%classParamType%;
<DEFn>=%classParamDefault%;
ARGS=%classArguments%;
Where:
  • n is the parameter number you're after (starting at 1)
  • Stuff between % characters is the corresponding code template susbstitution macro for this data.
Simon
