Author Topic: How to create a Class Diagram  (Read 32008 times)
tantra
« on: May 30, 2010, 01:24:49 am »
I'm beginner in this field.
I have build the class diagram, but I'm so confuse with PRIORITY ( I need to put priority 1 to 5).
Can you suggest to me anytihing else
thnx for help...
Re: How to create a Class Diagram
« Reply #1 on: May 31, 2010, 03:58:25 pm »
You will need an enumeration for Priority, and use that as the type of your attribute Contract.priority
The enumeration Priority should then contain the values 1-5 (without a type)
tantra
« Reply #2 on: June 01, 2010, 08:47:07 am »
Hi Geert,
I've set priority, the priority is the value at 1-5, can you tell me specifically what to do.
Thank you for helping me
« Last Edit: June 01, 2010, 09:07:35 am by Tantra »
« Reply #3 on: June 01, 2010, 08:58:47 am »
I don't know where lies Contract.priority because I am new in UML (am learning), can you tell me where is located Contract.priority, lacking only a priority from 1 to 5 the application is or should rule the other thing
In your class "Contract" you have an attribute "priority: int". That should be "priority: Priority".
tantra
« Reply #4 on: June 01, 2010, 09:50:58 am »
Hi, now is it OK?
« Reply #5 on: June 01, 2010, 12:55:50 pm »
No,
The class Priority should be an enumeration.
Look in the toolbox. There should be an icon for enumeration.
Drag that onto your class diagram and add the values 1-5 via the attributes.
tantra
« Reply #6 on: June 01, 2010, 08:05:47 pm »
No,
Now is it OK?
« Reply #7 on: June 01, 2010, 08:48:54 pm »
No, you now have a class with the name "enumeration".
You need an enumeration with the name "Priority".
Please lookup "enumeration" in your UML book/course (or even in the EA help file)
metamorphium
« Reply #8 on: June 01, 2010, 09:16:34 pm »
you'll want to do something like this:
You'll also want to name your enum more reasonably. :) Like "Low, Medium, High" instead of "Priority1" etc. :)
« Reply #9 on: June 01, 2010, 09:55:40 pm »
Typically you wouldn't add a type to your enumeration literals.
So you would have attributes with priority1 as name, but without a type.
The fact that you can assign something like an integer to an enumeration value is a programming construct, but not supported in UML.
metamorphium
« Reply #10 on: June 01, 2010, 10:03:37 pm »
However the EA documentation speaks otherwise:
http://www.sparxsystems.com/uml_tool_guide/sdk_for_enterprise_architect/addingenumerationstagstost.htm
Or am I gettin something wrong?
beginner
« Reply #11 on: June 01, 2010, 10:14:21 pm »
The ordinal value for the enum is typically supplied by the compiler (much later then). It might start from 0 or 1. But you're free to add numbers if you so wish.
b.
P.S. What is this here? An UML lecture? To the thread creator: go and do your homework first...
« Reply #12 on: June 01, 2010, 10:47:07 pm »
What do you think she is trying to do ;D
tantra
« Reply #13 on: June 01, 2010, 11:03:34 pm »
I build this diagram, can you tell me exactly what I do for the diagram be OK?
beginner
« Reply #14 on: June 02, 2010, 05:07:55 am »
Read the requirements detailed in your specification. Do you think that all of the are fulfilled? I don't.
b.
