Author Topic: Visibility vs Scope  (Read 16305 times)
Visibility vs Scope
« on: July 17, 2005, 01:32:32 am »
In a number of places, EA uses the term Scope for the enumerate values:
public
private
protected
package
In other places the term Visibility is used with the enumerate values:
Implementation
Private
Protected
Public
(Note the lack of camel case)
UML2 defines VisibilityKind as:
public
private
protected
package
So it's obvious that ER's scope is UML's VisibilityKind,  but what is EA's Visibility in UML terms?
Also, the Class Visibility doesn't appear on the CTF.
Thanx,
SF_lt
  • The Truth Is Out There
Re: Visibility vs Scope
« Reply #1 on: July 17, 2005, 11:31:25 am »
so implementation is like a garbage in the box :)
registertm everything to SparX
« Reply #2 on: August 17, 2005, 12:25:37 am »
The EA help file defines:
visibility
An enumeration whose value (public, protected, package or private) denotes how the model element to which it refers may be seen outside its enclosing namespace.
...and is deathly silent on scope... ???
So, my original question still stands...  Sparxians, can you tell me?
« Last Edit: August 17, 2005, 12:28:26 am by PaoloFCantoni »
sargasso
« Reply #3 on: August 17, 2005, 04:30:10 pm »
Where does "visbility" appear in element forms?
« Reply #4 on: August 17, 2005, 05:01:12 pm »
Where does "visibility" appear in element forms?
bruce,
It's on the Class|Detail tab.  I haven't looked on any other elements.
I just checked.  That control doesn't seem to be emitted by the interface.  It seems to be like the cardinality/multiplicity problem...
Cardinality:  Class|Detail|Cardinality
Multiplicity:  Class|General|Advanced|Multiplicity
Multiplicity is emitted, cardinality is not.  Maybe Sparxians should remove these two unused controls or tell us how and where they are used? ::)
BTW: the help file for the Element AI has the following entry:
Visibility    String     Read/Write. The Scope of this element within the current package. Valid values are: Public, Private, Protected or Package.
Is it any wonder my "little brain" hurts ???
sargasso
« Reply #5 on: August 17, 2005, 07:34:13 pm »
Weirdity!
" tell us how and where they are used? " please
bruce
« Reply #6 on: June 16, 2010, 07:17:10 pm »
[size=18]...[/size]
I came across this "golden oldie" while searching on another topic...
Sparxian Roy,
The Help file still says what it said in 2005, but the drop down now (857) says:
Implementation, Private, Protected or Public
While you're fixing that - an explanation of the difference between the two (Visibility/Scope) would be good.
(Both Visibility and Scope are persisted to t_object)
TIA,
