Author Topic: Custom properties and tagged values  (Read 16749 times)
beginner
« on: June 16, 2010, 09:18:04 pm »
Here's another one for the UML gurus. I wonder why Sparx has introduced Advanced/Custom properties. Aren't these just tagged values? E.g. for action pins the custom properties are used for in/out. Ports (from SysML) make use of a tagged value. What is the logic behind this?
The disadvantage of custom properties is on the hand: you have to perform complicated click operations while tagged values are always visible in the docked window.
b.
Re: Custom properties and tagged values
« Reply #1 on: June 18, 2010, 06:04:39 pm »
Apparently they have introduced the "custom properties" to be more flexible.
I think most of the custom properties are actually regular properties from a UML point of view. I guess it was just easier to add a custom property then to add a regular one.
beginner
« Reply #2 on: June 18, 2010, 09:09:44 pm »
Likely the custom dialogue is easier to customize than the regular. However, why not using tagged values for the purpose. These are nothing else but "custom properties", aren't they?
b.
« Last Edit: June 18, 2010, 09:10:14 pm by beginner »
« Reply #3 on: June 18, 2010, 09:57:25 pm »
Would that make it a bit complicated?
Because that would mean that standard UML attributes are being mixed with tagged values, which are bound to a profile.
beginner
« Reply #4 on: June 18, 2010, 11:17:42 pm »
I don't mean the standard attributes. Only those you get from context Advanced/Custom Properties. They are not standard anyway, are they?
b.
« Reply #5 on: June 19, 2010, 12:06:34 am »
Actually they are, that's what I meant.
For example the "isderived" attribute of an association is stored in the custom properties, while that is a standard UML attribute.
beginner
« Reply #6 on: June 19, 2010, 12:45:21 am »
I see. Thanks, Geert.
b.
