Author Topic: Cannot export a profile from EA to an ATL project  (Read 24595 times)
ACisneros
« on: August 26, 2010, 01:51:23 pm »
Hello
I have the following problem. I defined a profile using EA and exported it to an XMI file, then I imported this XMI file into Eclipse to use in an ATL project. I realized that Eclipse is not importing the file correctly since when I opened the file using the UML Editor it displayed a mess.
I notice that the XMI files generated by EA are coded using windows-1252, whereas the XMI files created using the tools in Eclipse and EMF are coded using UTF-8. Is this the root cause of the problem?
Thanks. Regards.
mrf
Re: Cannot export a profile from EA to an ATL proj
« Reply #1 on: August 26, 2010, 03:03:18 pm »
You can specify the code page that XML is output with in
Tools | Options | XML Specifications
Let us know whether changing it to UTF8 helps!
Best Regards,
Michael
ACisneros
« Reply #2 on: September 03, 2010, 11:56:07 am »
Sorry, that didn't work. I had to do all of my meta-modeling, modeling and model-transformation using Eclipse plugins  :'(
I was (to some extend) able to import the target model produced by the ATL transformation into Enterprise Architect. I have not figured out how to check the values of the tagged values of the instances of the stereotypes in such imported model. Any ideas?
Regards
