Author Topic: USE case update in robusness analysis diagram  (Read 13912 times)
seamoh
« on: January 31, 2011, 10:44:04 pm »
Hello and thank you very much for your attention:
I am starting to draw robustness analysis for a usecase in Enterprise Architect. As you know
the use caste text is inserted on the left on robustness analysis.meanwhile I notice to add an
alternate path for the usecase ,when I add the alternate path for the usecase  ,the use caste
text on the robustness diagram doesn't update (doesn't add this new added alternate
path).Please help me I am in a hurry
Re: USE case update in robusness analysis diagram
« Reply #1 on: January 31, 2011, 11:54:49 pm »
Not clear what you're actually doing. Iconix is using plain notes from the UC in the diagrams. From what you say it looks like you use the structured scenarios.
seamoh
« Reply #2 on: February 01, 2011, 01:16:23 am »
Hello and thank you very much for the response. No I use general tab ,but when I add a thing in general tab ,it will not reflected on robustness analysis .and it make my works very hard. I think when I change my usecases ,it should be reflected on usecase test on robustness analysis soon. I hope I can tell my problem clearly.
Thank you
« Reply #3 on: February 01, 2011, 03:17:17 am »
How did you create the note? Link Note with UC. Context for Note Link. Link this Note to an Element feature...
