Author Topic: Open MS Access from EA  (Read 5704 times)
Maarten
« on: August 15, 2005, 11:44:27 pm »
In the help documentation on automation one can find that it is possible to call an external application from within EA. I set this up for MS Access an defined the argument $f such that my EAP file was directly opened in MS Access.
Unfortunately this does not seem to work when the name of the EAP file contains a space. Hence my shortcut worked fine for a file with a name like C:\MyPath\MyFile.eap. However when I tried it for a file with a name like C:\MyPath\My File.eap it did not work because MS Access could not find the file C:\MyPath\My.mdb.
Does anyone know if it is possible to avoid this 'trunc' of the file name?
Re: Open MS Access from EA
« Reply #1 on: August 16, 2005, 02:03:57 am »
Har har! This MS DOSis! Parameters are passed with string separators (blanks). I made a rather strange hack to get across this one (filling in unusual string delimiters and concatenate between - does not work with filename that have multiple blanks).  :o
mikewhit
  • Accessing ....
« Reply #2 on: August 16, 2005, 03:26:10 am »
Don't suppose using %20 for 'space' helps, does it ?
Maarten
« Reply #3 on: August 16, 2005, 04:26:44 am »
Using the %20 solution requires that I know my filename in advance. I thought it was possible to configure a generic solution that would open the active EAP file in MS Access by using the parameter $f. If I know my filename I can simply use it and put it between quotes (according to the EA-help that should also function).
« Reply #4 on: August 16, 2005, 07:45:42 am »
You might look into my Perl/BAT coding on EAUG.
