Author Topic: Reverse engineering XSD  (Read 6527 times)
mcoletti
« on: August 12, 2005, 02:34:34 am »
I have the need to create an UML model representing an XML Schema defined through an XSD file.
I think that an XSL transformation from the XSD to an XMI model, could help in the reverse-engineering process.
Did anyone find this problem interesting or is aware of already developed tools?
Massimo
Re: Reverse engineering XSD
« Reply #1 on: August 12, 2005, 08:09:52 am »
Not yet. See here.
mcoletti
« Reply #2 on: August 14, 2005, 09:31:25 am »
thanks, Thomas.
I have read the thread, now it will be useful to understand the planned "release" of this feature, in order to decide if it is better to implement a "skeleton" transform to fulfill my basic requirements or wait for the packaged feature.
Massimo
alx
« Reply #3 on: August 15, 2005, 05:08:38 pm »
One option is the [free] hyperModel plugin for Eclipse. It produces UML 1.3 XMI 1.0 with UML Profile for XML Schema, can be imported in EA.
http://www.xmlmodeling.com/hyperModel/index.html
mcoletti
« Reply #4 on: August 17, 2005, 01:38:13 am »
I have quickly tried it, with XBRL specifications, and it worked smoothly! Thanks.
Massimo
