Author Topic: Sequence Diagram - information exchanges  (Read 11769 times)
CWainwright
« on: June 15, 2011, 10:34:33 pm »
I would like to have a link between the Roles I have defined in my Organisation Chart (using a logical Class Diagram) and the information exchanges (modelled as Information Elements) as part of a Sequence Diagram.  I.e. showing the information passed between the roles and their sequence.
I am only given the option to draw messages, which even when I use the "Advanced" menu option to select "Information Flows Realized..." I cannot link my previously defined Information Elements.
Does anybody know how I might do this?
ngong
Re: Sequence Diagram - information exchanges
« Reply #1 on: June 29, 2011, 02:50:24 pm »
Do not know if this helps, CWainwright:
When designing messages you are able to define an operation for it moving parameters to the destination object and returning return values from the destination object.
You are able to define this data to belong to certain type. There is where your pre-defined classes come in.
Kind Regards
Rolf
« Last Edit: June 29, 2011, 02:51:02 pm by ngong »
Rolf
