Author Topic: Access to Property metadata  (Read 9689 times)
« on: August 17, 2005, 12:13:39 am »
When you wish to expose the class attribute as a property, you tick the property box and this enables the Property information dialog.
There doesn't seem to be any way to access this via the Automation Interface.  Does anybody know how to do it?
In any event, what do the Read and Write checkboxes mean on the Property information dialog?
Inquisitively,
« Last Edit: August 17, 2005, 12:13:56 am by PaoloFCantoni »
Re: Access to Property metadata
« Reply #1 on: August 17, 2005, 03:29:28 pm »
Is the property you are exposing read-only, write-only or read/write?
What this looks like is dependant on the language.
I don't think that functionality is available through the automation interface, but it just creates one or two methods that link back to the attribute.
Simon
« Reply #2 on: August 17, 2005, 03:59:36 pm »
Simon
Thanx Simon,
So these checkboxes determine (in theory - since I can get at them yet...) whether the setter or getter are actually created.
If you reverse engineer (at least in C#) it doesn't link back to the attribute...  It just creates some operations.  There's no linkage to the attribute...
Will this dialog be exposed in the next release?
« Reply #3 on: August 17, 2005, 04:12:18 pm »
If the property aligns with the attribute according to the rules about how properties are created, it does link it back to the property.  (At least it just did in my test case)
I don't think the dialog is likely to be exposed in the near future.  I would recommend just creating the methods yourself.
Simon
« Reply #4 on: August 17, 2005, 05:15:22 pm »
Was that C#?
You make a good point though Gunga-Din.  My code was:
private int currentLevel;
public int Level
 get
   return currentLevel;
 set
   currentLevel = value;
Which DOES not conform to the suggested format.  Since you can change the name...
Simon
I have developed an alternative technology for simulating missing EA functionality for my emitter.  It's just a pain to have to do it...
