Author Topic: Dependancy between requirement and attributes  (Read 13838 times)
OpenIT Solutions
« on: November 19, 2011, 12:49:46 am »
Is there am easy way in UML to show a dependancy between one or more attributes of a class and say a requirement/use case ? I know i can use the "Link to Element Feature" capability, can you recommended any other approaches?
Jon.
Re: Dependancy between requirement and attributes
« Reply #1 on: November 19, 2011, 01:26:20 am »
Association & source/target role.
But I don't know whether this would be a recommendation.
« Reply #2 on: November 19, 2011, 01:33:02 am »
Tagged values
You can setup tagged values of type refGUID and limit the type to Requirement.
That will allow you to select a requirement to link to the attribute.
« Reply #3 on: November 19, 2011, 01:47:25 am »
refGUID did not really work for me when using it in a MDG. We had a lot of trouble with that. Instead of the element the GUID showed up when displayed via ShapeScript. Also (maybe this is fixed in-between) the selection did not work under some circumstances.
But if it was working it would be an alternative...
OpenIT Solutions
« Reply #4 on: November 26, 2011, 01:54:42 am »
Thanks for the suggestions....it would be best for my users if created a tagged value of refguidlist against the Requirment so they could select the associated "Attributes"....i've tried...doesn't seem to work...as attributes are not listed in the browser (only classes etc)...Am i right in thinking it will not be possible to pick Attributes ?
Jon.
« Reply #5 on: November 26, 2011, 03:28:58 am »
Actually attribute ARE shown in the browser, and they can be used in RefGUID type of tagged values.
