Author Topic: Tagged values as RTF  (Read 14736 times)
supplyondemand
« on: December 17, 2011, 01:26:09 am »
Is it possible to define a tagged value not just as text/char but as RTF like in the Notes box of an element?
I know how to use basic tagged values and how to define profiles. I also know that I could link external documents to an element, but I would like to have the information directly within the element.
Thank you.
OpenIT Solutions
Re: Tagged values as RTF
« Reply #1 on: December 17, 2011, 01:38:34 am »
Yep set the type="memo" in your uml profile...
supplyondemand
« Reply #2 on: December 17, 2011, 01:49:23 am »
Thank you very much, but could you be a bit more specific?
So far when I define a profile, I define the tagged values as Attributes in the Stereotype (which I link to the metaclass through the Extension relationship). Here I can only set types like "int", "boolean", "char" etc.
How can I set the "memo" type?
philchudley
« Reply #3 on: December 17, 2011, 01:57:20 am »
Step 1 - Define the TaggedValue using the main menu Settings | UML Types ...
type=Memo;
Step 2: - In your profile, use an attribute of the same name as your TaggedValue
Please note, you may have to export / import your tagged values in addition to your profile to all projects in which the profile is to be used
Cheers
Phil
Models are great!
supplyondemand
« Reply #4 on: December 20, 2011, 07:05:17 pm »
Thank you, it works now!
Just to point out for others again: you need to set the "name" of the attribute to the value of the "Tag name" in "Settings - UML Types - Tagged Value Types", not the "type" (as I did).
