Author Topic: how to model java statment "package ch.axa  (Read 12266 times)
Josef Stadelmann
  • as simple as possible, but not too simple
« on: June 22, 2012, 12:23:28 am »
how can I model the java language statment "package ch.axa"
I have successfull rount trip engineering with my java project. And so it is getting bigger every day. That is when classes go into a package structure i.e. in java source code the class HellopWorld shall go into a package called "ch.axa". Hence the class HelloWorld.java becomes the canonical class name of "ch.axa.HelloWorld" and resides at src/main/ch/axa/HelloWorld.java
in other wods: When I refactor my code to move src/main/HelloWorld.java to src/main/ch/axa/HelloWorld.java my IDE (NetBeans) does all the name changes at the java class level and changes package names and creates directories on demand or renaes them. After a sucessfull build by the NetBeans IDE, I would like to synchronize my code base with the model. Hence I would expect to see the changes somewhere in the model. i..e. looking at a class diiagram should somehow indicate in which (package) the class can be found.
my question is: where can I see this in the model.
Which modelling elements (pakage diagrams with import and merge relations) do I miss to establish prior to going for a code refactoring followed by a synchronize code with modell from EA?
OK - the true is that when I modify in my source code the package names and re-import from that source directory the changes become visible. this with the default, the package per namespace toggeled.
BUT - synchronize does not end up in such changes. Is that a bug or a feature. I would think that in case of larger projects, reimporting over and over again after refatoring is teddious. For a smal change such as a move of a class to another package a sync should do it to refelct the change correctly in at lerast in the project browser/window.
« Last Edit: June 22, 2012, 02:32:17 am by stadelma »
