Author Topic: Generating XSD Schema  (Read 13964 times)
Appollo
« on: October 12, 2012, 02:21:44 am »
I have a class diagram with XSD types, and when I try to generate XSD schema (Code Engineering-> Generate XSD schema), I get the following error (in Progress text area on Generate XML schema dialog):
One or more Packages missing Fileame.
I get that message/error, even if I select "Prompt when Filename" checkbox.
Any help would be appreciated.
Thank you,
salayande
  • I love YaBB 1 Gold!
Re: Generating XSD Schema
« Reply #1 on: December 01, 2012, 11:43:12 am »
It appears like a reference issue.
It is a type of problem best solved by sending the model file to Sparxsystem.
