Author Topic: Version 3.51 - Build 611 Released  (Read 22385 times)
sparks
« on: May 07, 2003, 12:37:40 am »
Changes in Build 611
Fixed bug in EA running under Windows 2000 that could result in program termination when adding a new Project Root node
Fixed problem with UML Patterns when adding sequence objects and messages to an existing diagram - could result in duplicate messages being created
Fixed problem with Classifier dialog not showing correct classifiers for some intance types
Added option to View/Options/Diagram/Behaviour dialog to turn off Automatic Sub-Activities from dropped diagrams
Fixed issue with new Sub-Activities created from dropped diagrams not appearing in Project Browser until a reload occurred
Fixed issue with import of XMI - attribute and element contraints could cause an error if constraint type was not set in XML file
Modified export of 'position'tagged value in XMI 1.0 for attributes - used tag name ea_position instead to avoid conflict with XSD position tagged value
Modified RTF generator to sort connectors by connector type first, thereby grouping like connectors
Modified RTF generator to fix issue with line breaks in Test notes
Fixed issue with glossary dialog not warning if pending changes exist when moving between records or closing the dialog
