Author Topic: Alternatives to Information Flow connector?  (Read 19315 times)
Andreas1975
« on: April 03, 2013, 02:17:17 am »
Hi.
I'm modelling a system containing a massive amount of various integrations, including i.e. FTP and MQ technologies.
I would prefer modelling all FTP interactions using the "Information Flow" connector, and having the actual File information as a Conveyed Item.
However - Using the Information Flow, its not easy to navigate (in diagram, searches, html reports etc) between the elements as well as to/from the actual File object conveyed. (since the File technically is attached as a Xref on the Connector)
I also would prefer to not model the actual FTP communication as a separate object, since using the Connector would be more "pretty". Using Tagged Value on the Information Flow to point out the File is not very user friendly.
What I really would like to do is adding a File object to the Information Flow connector as a "normal" relation.
Or is there any other way to model this in a "proper" way, making the flows easy navigable and searchable?
regards
Andreas
Helmut Ortmann
Re: Alternatives to Information Flow connector?
« Reply #1 on: April 03, 2013, 02:43:07 am »
there are some ways to model the conveyed information between classes or so:
  • Use ports, connections and interfaces
  • Use ports and type them by the conveyed information
  • Make an association and use an association class
  • Make flow with a class conveyed (the class contains all the subinformation)
  • Using Composite Structure Diagrams to visualize the concrete connections (with ports, conveyed items, interfaces)
  • Provided, Required Interface
I personally prefer port/type and connector.
Be also aware that there are a semantic differences between the solutions. But who cares?
Best regards,
Helmut
« Reply #2 on: April 03, 2013, 07:53:38 am »
To augment what Helmut said: If your model look clear and you "think" the reader understands your thoughts it is fine. If you are in doubt, look for someone to discuss your designs.
Helmut Ortmann
« Reply #3 on: April 03, 2013, 08:08:13 am »
A short but valuable remark. Thanks a lot.
Helmut
Andreas1975
« Reply #4 on: April 04, 2013, 12:35:20 am »
Thanks alot. Good inputs.
I will try out some of the approaches above - You guys definately have a point of a clear model. Most of my readers are not "uml compliant", and its a challenge to model this in a clear way.
Andreas1975
« Reply #5 on: April 04, 2013, 12:45:41 am »
