Author Topic: Alternative path nested  (Read 15134 times)
Luiz Perciliano
« on: April 17, 2013, 10:59:01 pm »
I need nested the alternative path at other alternative path, but the EA 10.0 i don“t get, this is possibile?
Thanks.
Re: Alternative path nested
« Reply #1 on: April 18, 2013, 05:02:37 pm »
No, you can only make alternate or exception scenario's for the main scenario.
« Reply #2 on: April 18, 2013, 06:05:52 pm »
I used a naming/numbering scheme which made clear which path is active at a time. It's a bit manual overhead but creates readable documentation. A drawback is that the numbering must be controlled throughout the scenario if you insert steps.
Luiz Perciliano
« Reply #3 on: April 18, 2013, 10:39:11 pm »
ok,
i don't know make now, but seek a solution.
thank you.
