Author Topic: Unexpected symbol  (Read 25830 times)
waleriadavid
Unexpected symbol
« on: July 30, 2013, 04:30:32 am »
Can anyone help me?
I'm trying to generate a class diagram, using reverse engineering, but the following is happening. See the error:
There was an error parsing C:\Documents and Settings\Meus documentos\EA_Documentos\Modelos\Environment\class\CSIMEnvFactory.h  on line 11.  Unexpected symbol: ISIMFactory
You may need to define a language macro.
There was an error parsing C:\Documents and Settings\Meus documentos\EA_Documentos\Modelos\Environment\class\CSIMEnvironmentModel.h  on line 99.  Unexpected symbol: ISIMModel
There was an error parsing C:\Documents and Settings\walera.antunes\Meus documentos\EA_Documentos\Modelos\Environment\class\CSIMEnvironmentModel.h  on line 99.  Unexpected symbol: ISIMModel
See part of my code: http://paste.ofcode.org/LKUrGHZ9PVmchjB6fBkvrn
What can it be? Can you help me?
« Last Edit: July 30, 2013, 11:59:27 pm by waleriadavid »
Re: Unexpected symbol
« Reply #1 on: July 30, 2013, 05:03:03 am »
Do as suggested and define the language macro ISIMModel.
waleriadavid
« Reply #2 on: July 30, 2013, 05:16:19 am »
I need define the language macro ISIMModel using EA- Enterprise Architect?
How to do it? I am beginner user of EA
« Reply #3 on: July 30, 2013, 06:29:09 am »
Open the help
Type "language macro" in the search field
Show the 2nd entry
g.makulik
« Reply #4 on: July 30, 2013, 07:35:14 am »
See my answer at stack overflow (http://stackoverflow.com/questions/17931668/enterprise-architect-reverse-engineering-unexpected-symbol-error/17931762#17931762), it explains fairly well where you should look into!
Günther
« Last Edit: July 30, 2013, 07:35:36 am by g.makulik »
waleriadavid
« Reply #5 on: July 30, 2013, 10:18:50 pm »
I defined the language macro to ISIMModel, but now this error occurs. See please.
There was an error parsing C:\Documents and Settings\Meus documentos\EA_Documentos\Modelos\Environment\class\CSIMEnvFactory.h on line 12. Unexpected symbol: { You may need to define a language macro. There was an error parsing C:\Documents and Settings\Meus documentos\EA_Documentos\Modelos\Environment\class\CSIMEnvironmentModel.h on line 99. Unexpected symbol: , You may need to define a language macro.
What I should do?
Makulik
« Reply #6 on: July 31, 2013, 12:43:27 am »
According to what I see in your code you'll need to define a language macro for SIMMDLENVv01_EXPORT, not for ISIMModel (which is your class name!).
waleriadavid
« Reply #7 on: July 31, 2013, 01:43:19 am »
That's what I'm trying to do, but how I do it?
I went to "Settings" -> "Macros Processors ..." and added "SIMMDLENVv01_EXPORT" but the error continue.
Makulik
« Reply #8 on: July 31, 2013, 02:46:24 am »
Don't forget to remove any settings you made previously for the wrong symbols!
waleriadavid
« Reply #9 on: July 31, 2013, 03:08:30 am »
Thank so much!!! It was just that I had forgotten to remove the previous settings ....Thank you very much!!!  :)
g.makulik
« Reply #10 on: July 31, 2013, 03:46:56 am »
De nada!
Solved stupid mistakes are the ones that will give you the best achievable learning effect. 8-)
Best regards,
Günther
« Last Edit: July 31, 2013, 03:47:45 am by g.makulik »
