Author Topic: File types - Can they be changed?  (Read 6632 times)
« on: September 02, 2005, 12:31:12 am »
The file types in the Files tab of the Classifier dialog...
Are they hard coded?
Or can we change them in some way?
Cheerz,
Re: File types - Can they be changed?
« Reply #1 on: September 05, 2005, 01:33:09 am »
can be found where?
« Reply #2 on: September 05, 2005, 02:41:30 am »
can be found where?
Pick any Classifier (such as Class, Interface etc) (or even any Element ;D) Properties (Alt+Enter)... The Files tab should be the rightmost on the Tab list (General is the leftmost).
« Reply #3 on: September 05, 2005, 03:34:05 am »
Ah - the obvious one. Overlooked that ;D
I know of no way to change the type (local/web). Edit: it's hard coded in EA.exe. What would you like to appear?
« Last Edit: September 05, 2005, 03:38:00 am by thomaskilian »
« Reply #4 on: September 05, 2005, 03:47:04 am »
Not sure yet!  That's why I'd like it to be configurable.  The two current values:  Local File and Web Address are somewhat specious.  They are about file location types, not file types  If you define a location in URL terms, whether it's local or not is dependent on where you are, not where it is...
I suspect that the kinds of values you find in the Windows Explorer under Type are more appropriate (and hence should be configurable).
« Reply #5 on: September 05, 2005, 03:49:08 am »
Probably a candidate for Suggestions.
Look in t_objectfiles. You can change the value and it appears in the file list. But the drop down is - as said above - hard coded.
« Last Edit: September 05, 2005, 03:49:44 am by thomaskilian »
