Author Topic: How To Template Bind Between Diagrams  (Read 14276 times)
kadir
« on: February 26, 2014, 09:48:39 pm »
I have 2 diagrams: Core and Context.
There is an abstract generic base class called Entity within Core. I can create new classes from entity by directly drag-drop onto my Context diagram and select "as a New Child". But while my base class is a generic class I have to bind the template for derived classes. So I have to put the Entity class into my Context diagram as a simple link and everything is fine.
Unfortunately, while there are many classes and everyone one them are derived from Entity, after a while, there become a connector jungle: 20 classes in which each of them generalizes the base entity with binding connectors and also some connections between them is hard to follow.
If I just try add a binding from Properties > Templates menu of the Element I get a warning saying "Target Object not found in current Diagram!"
Hence I wonder if there is a way to add a binding without the need of putting the base element into the working diagram or at least avoid the connector jungle.
Regards.
Re: How To Template Bind Between Diagrams
« Reply #1 on: February 26, 2014, 11:00:56 pm »
If you remove the general class from the diagram it will appear in italics in the generalized children. Won't that help?
kadir
« Reply #2 on: February 27, 2014, 12:37:35 am »
Unfortunately no..  :-[
Have tried your suggestion but the general class did not appear in italics in the generalized children.
« Reply #3 on: February 27, 2014, 09:49:05 pm »
It should look like that:
Left diagram shows class and generalization. The right diagram just the class.
kadir
« Reply #4 on: February 28, 2014, 02:06:48 am »
Here is the whole story:
1. I have an abstract generic base entity in another diagram..
2. When I drag-n-drop it as a simple link to another diagram..
3. And I generalize a class from this base class and bind the template, everything is great..
4. Now, as I wrote, there will be a lot of classes so the diagram will be a mess, so when I delete the base class just from the diagram as you suggested, nothing happens, no italics nor anything..
5. So I tried directly to generalize a class by drag-n-drop..
6. VoilĂ , the base class is in the element box as italics, hooray..
7. But where is the template binding, I tried to add one..
8. And this is what I got..
A really appreciate your efforts but unfortunately what I am trying to do is a bit different and I still hope that there is an answer for this problem. Thanks in advance and sincere regards.
« Reply #5 on: February 28, 2014, 06:47:59 am »
I see, but currently I have no answer. However, someone else might chip in.
« Last Edit: February 28, 2014, 06:48:40 am by qwerty »
kadir
« Reply #6 on: February 28, 2014, 11:08:28 pm »
Thanks @qwerty..
