Author Topic: Generating C++code from class diagram causes error  (Read 13240 times)
Elvys
« on: August 26, 2014, 05:08:16 pm »
Hallo there,
I'm trying to generate C++-Code from a class modeled with EA10.
The path where the code has to be generated has a pattern like
D:\_Projects\Project123\Mod123\
Well, when I click on "Generate" a dialog appears indicating that
An error occurred opening the file:
D:\_Projects\Project123\Mod123\D:\_Projects\Project123\Mod123\File.cpp
The corresponding h-file is created in the right folder without problems.
For tests I have created a dummy-project on my desktop.
I modeled a class (with a few dummy methods) and tried to generate the code.
I was surprised to see the dialog with the message:
C:\Users\elvys\Desktop\D:\_Projects\Project123\Mod123\Class1.cpp
As you can see the path of the project I was modelling first is somewhere saved.
The same model can generate java code without problems.
About my system:
OS: Win7Pro SP1
CPU: Intel Core i7 2640M@2,8GHz
License type: Floating (But at the moment I’m the only one using EA because the other developers are on holiday).
I hope you can help me.
Thank you in advance
Elvys
Re: Generating C++code from class diagram causes e
« Reply #1 on: August 28, 2014, 08:40:07 am »
What is the value of Tools | Options | C++ | Source Path?
I'm expecting something like D:\_Projects\...
The option expects a relative path to the location of the header files. (The default is .\)
Elvys
« Reply #2 on: September 02, 2014, 04:43:05 pm »
Halo Simon,
sorry for the delay: I expected a notification that never came.   :'(
You were absolutelly right - The path was configured with the D:\...-directory.
This makes my day.  ;)
Thanks again
Elvys
