Author Topic: Activity Diagram  (Read 21532 times)
ayman
Activity Diagram
« on: October 21, 2014, 07:57:04 pm »
how to add parameter to an activity?
what the attributes is used for?
what the operations is used for?
Re: Activity Diagram
« Reply #1 on: October 21, 2014, 08:17:32 pm »
Just choose Properties/Parameters and add them. To make them appear in te diagram select Structural Components in the context of the diagram object and tick the ones you want to see.
I have never used attributes/operations for activities. Maybe there is some use for them. You'd need to check Superstructures. But simply speaking: if you don't know what it's good for - ignore them. If you see them in use somewhere ask the author what he wanted to express.
ayman
« Reply #2 on: October 21, 2014, 09:31:47 pm »
there is no parameters tap in properties as u have mentioned after right click on activity node
« Reply #3 on: October 21, 2014, 09:42:19 pm »
I just verified, and in v 11.0.1107 there is definitely a Parameters "tab" in the properties dialog of an Activity (double click on Activity)
ayman
« Reply #4 on: October 21, 2014, 09:43:55 pm »
ya u are right thanks the difference is related to the version
