Author Topic: Adding visible stereotype to Realization  (Read 44669 times)
0xCAFEBABE
« on: November 24, 2014, 02:58:37 am »
Hello. In a component diagram, can't I add a visible Stereotype to a Realization from a (Packaging)Component to another Component?
I want to make it visible what exactly gets implemented by another Component.
Do I really have to use a different relationship than a Realization? Would an "Assembly" be most fitting as the replacement in this case?
« Last Edit: November 24, 2014, 03:01:18 am by 0xCAFEBABE »
Re: Adding visible stereotype to Realization
« Reply #1 on: November 24, 2014, 04:42:31 am »
I just create a Realize from a packaging component to a component (though that does not seem to be UML compliant) and added a stereotype which was showing with no issue.
« Reply #2 on: November 24, 2014, 12:37:52 pm »
Seems valid to me. UML has a dedicated type ComponentRealization for this scenario. EA only provides a single realization connector and works out the difference when exporting to XMI.
« Reply #3 on: November 24, 2014, 04:46:00 pm »
My above assumption was only based on he fact that EA does not offer such a relation as per default from the QL. I have not cross checked with Superstructures. However, it is independent of the OP's basic issue.
DBRN
« Reply #4 on: December 12, 2014, 09:56:48 pm »
Hi. What about realizations of other UML-elements, i.e. classes or packages?
I can make a Dependency, an Association, a Generalization and they all show a <<stereotype>>, just not Realization? Can I enable it somewhere? I cannot confirm what qwerty says; I see nothing under the arrow of any created Realization with specified stereotype.
« Last Edit: December 12, 2014, 10:01:00 pm by cafebabe »
« Reply #5 on: December 12, 2014, 11:10:23 pm »
Check the diagram properties/Connectors/last checkbox.
DBRN
« Reply #6 on: December 12, 2014, 11:26:25 pm »
It is checked. I can see all the other stereotypes in the diagram; for dependency, association, generalization. Just not for realization.
« Reply #7 on: December 12, 2014, 11:40:47 pm »
Which version do you use?
DBRN
« Reply #8 on: December 13, 2014, 12:09:40 am »
Program version 10.0.1005
Database version 4.01
Registered EA Corporate Edition
« Reply #9 on: December 13, 2014, 03:35:18 am »
So there's the reason. V10 does not show it. V9.3 and V11 do. Time for up- or downgrade ::)
« Last Edit: December 13, 2014, 03:35:34 am by qwerty »
kwasposer
« Reply #10 on: February 18, 2020, 11:25:32 pm »
I ve got version 14.1.
I have pointed from one package to another inside the bdd with a realization arrow.
I would like to have the stereotype "realization" be visible.
« Reply #11 on: February 18, 2020, 11:29:14 pm »
This is a dead thread. You should start a new one.
« Reply #12 on: February 19, 2020, 11:01:51 am »
There is no stereotype "realization" that applies to a Realization connector. You are welcome to define one.
