Author Topic: How can I know the original type of a diagram  (Read 16995 times)
dangel
« on: February 19, 2015, 02:37:02 pm »
How can I know the original type of a diagram like if it is: Structural or Behavioral type, by diagram GUID or ID or Type?
Re: How can I know the original type of a diagram
« Reply #1 on: February 19, 2015, 03:14:27 pm »
Source: Wikipedia
« Last Edit: February 19, 2015, 03:15:40 pm by KP »
dangel
« Reply #2 on: February 20, 2015, 03:54:42 am »
but how can i know the original type using guid-of-diagram. Api/ sql in EA
« Reply #3 on: February 20, 2015, 06:46:13 am »
Check the type and use the diagram above to deduce it.
dangel
« Reply #4 on: February 20, 2015, 07:03:12 am »
OK, so you mean there is no query or API to do that in EA ?
« Reply #5 on: February 20, 2015, 07:27:29 am »
Exactly. But getting the type and using a table will do, I guess.
dangel
« Reply #6 on: February 20, 2015, 07:45:21 am »
OK, I will do a virtual Table, C# (DataTable) or even HashTable to do 2 columns one for PK (diagram-type)  Value(Org-Type)
This was  my last solution, because I could not find EA-API for that.
Thank you for your help.
« Reply #7 on: February 20, 2015, 06:50:52 pm »
There's only thirteen different diagram types.
Why make life more complicated then it needs to.
A simple switch case would suffice.
Something like the code below.
public string getDiagramTypeGroup(string diagramType)
  switch (diagramType)
     case "ProfileDiagram":
     case "ClassDiagram":
     case "ComponentDiagram":
     case "...":
       return "StructureDiagram":
       break;
     case "SequenceDiagram":
     case "CommunicationDiagram":
     case "ActivityDiagram":
     case "...":
       return "BehaviorDiagram":
       break;
dangel
« Reply #8 on: February 21, 2015, 01:32:52 am »
It is OK, but I just wanted to ask if there are some API for that, because in future if some new types are added then my tool should be able to deal with the dynamic changes!
Anyway, thanks a lot
