Author Topic: Add tag value to existing metaclass/stereotype  (Read 16475 times)
Stanislaw Tristan
« on: April 21, 2015, 09:02:08 pm »
Hello!
Is it possible to avoid creation my own stereotype to add a tagged value for existing metaclass? for example, Requirement?
I want all requirements (existing and new) automatically have the defined tagged value.
Re: Add tag value to existing metaclass/stereotype
« Reply #1 on: April 22, 2015, 04:12:46 am »
You need to create a MDG the creates a (say) <<myRequirement>> extending a Requirement meta class. There you can add your own tags. Se here: http://community.sparxsystems.com/tutorials/552-24intro-to-creating-a-mdg-file
« Reply #2 on: April 22, 2015, 09:11:48 am »
To add a tagged value to all existing requirement elements, you will need to write a script. Your script should run a SQL select to find the requirement elements, then loop through them adding the tagged value.
To add a tagged value to newly created requirement elements, create a Project Template Package in your model containing a requirement element with the tagged value.
[But note that qwerty's answer is UML compliant and mine isn't because UML requires that tagged values are applied by stereotypes.]
« Last Edit: April 22, 2015, 11:35:49 am by KP »
