Author Topic: Ordering Complex Types  (Read 15950 times)
bluebird
  • after tomorrow
« on: August 20, 2015, 08:20:22 pm »
So  currently reverse engineering an XML schema in EA and we are now looking at generating the XSD and trying to validate against an example xml file.
However, the xsd schema file generated from EA, output some of the complex types in a different order than the original schema. Is there a way that this can be controlled in EA?
Note: We are aware of how to order elements within a complex type - that  isn't the issue.
Many thanks
Re: Ordering Complex Types
« Reply #1 on: August 21, 2015, 09:49:26 am »
Many thanks
Ah bluebird...
THE simplest (and perhaps most effective) reverse engineering technology test...  ForwardEngineer(ReverseEngineer(input))=Exactly(input).
That's how nearly a decade ago we were able to prove that the export/import function was seriously flawed  >:( (and showed over about 5 releases that the problem changed, but didn't get better...  :o).  When you're designing safety critical systems (EN 50128), near-enough ISN'T good enough....
That having been said, the input must be valid and ordered correctly.  ;)
« Last Edit: August 21, 2015, 09:51:17 am by PaoloFCantoni »
« Reply #2 on: August 21, 2015, 07:17:28 pm »
FWIW: Due to the semantic differences between XSD and UML and the limitations imposed we decided to write our own import/export. This way it was possible to react the way we needed it. It was not too difficult and implementing some constraint checking with meaningful messages paid off the long term.
« Reply #3 on: August 22, 2015, 11:27:23 pm »
I've done the same, a couple of times in the past.
bluebird
  • after tomorrow
« Reply #4 on: August 24, 2015, 07:50:53 pm »
Ok thanks for your replies. From what you say it seems like a Plan B outside of EA will be required.
