Author Topic: Version 3.51 - Build 613 Released  (Read 19481 times)
sparks
« on: May 30, 2003, 12:19:22 am »
Changes in Build 613
Added new diagram layout options:
  - Set from Diagram Dialog: see Set Layout button
  - Applies to current diagram only
  - Can be set as Project Default layout
  - Includes option to layout to left, right, up or down
  - Includes settings to control spacing and layout performance options
  - Also includes auto 'bending' of line links where possible to achieve a clean layout
Fixed 'Undo' of moved boundary where subelements are also moved
Fixed Undo of  diagram layout - Ctrl+Z will now reverse a layout
Added Connectors collection to Package element in Automation Interface
Added TreePos property to Element in Automation interface
Fixed error in options dialog default value for wrap long comments option
Fixed spelling errors in Generate DDL dialog
Fixed C++ parser error when importing some inline functions from header file
Added Alias property to Package element in ActiveX interface
Fixed 'Locate Object' behavior in Implementation Report dialog
Fixed error with code generation progress dialog that could result in dialog been left open when a bad filename was encountered in output
Modified Instance State behavior to remove merged name when this option is unchecked and to not show [state] in instance graphically when name is merged
Changed 'hit test' on sequence elements to only include the 'head' of the element and 7 pixels either side of the lifeline. This is to improve element selection in sequence diagrams
Fixed error with arbitrary packages being opened when EA first loads a project (bug in 612 only)
